Aller au contenu principal
HP Pavilion15z-eh000 SSD Replacement
Ce dont vous avez besoin
  1. HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: étape 1, image 1 de 3 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: étape 1, image 2 de 3 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: étape 1, image 3 de 3
    • Remove the two M2.0 × 5.0 Phillips screws along the bottom of the cover.
    • Remove the four Phillips M2.5 × 6.5 screws under the rubber foot pads.
    • The rubber pads have adhesive that allows them to be restuck after being lifted. You do not need to completely remove them, only partially.
  2. HP Pavilion15z-eh000 SSD Replacement: étape 2, image 1 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 2, image 2 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 2, image 3 de 3
    • Use an opening tool to pry open the bottom case, starting from the hinge.
    • Follow along the edge and use the opening tool to lever it open.
    • Recommended to start from the hinge as it will be easier, but it is possible to start anywhere.
  3. HP Pavilion15z-eh000 SSD Replacement: étape 3, image 1 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 3, image 2 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 3, image 3 de 3
    • Remove the six Phillips M2.0 × 4.0 screws holding the battery in place.
    • Lift the battery slightly and pull it to disconnect it from the connector on the motherboard.
  4. HP Pavilion15z-eh000 SSD Replacement: étape 4, image 1 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 4, image 2 de 3 HP Pavilion15z-eh000 SSD Replacement: étape 4, image 3 de 3
    • Finally, remove the Phillips M2.0 × 2.5 screw that secures the SSD to the motherboard.
    • Grasp the SSD by the edges and gently pull it out from its slot.
    • After removing the screw, the SSD will partially lift itself. Make note of the angle. When installing your new SSD be sure to insert it at the same angle.
Bryan Segovia
Membre depuis le 10/26/22
109 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 3-42, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 3-42, Briggs Fall 2022
CSULA-BRIGGS-F22S3G42
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 306
