Aller au contenu principal
HP Pavillion G7-2235DX Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: étape 2, image 1 de 1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: étape 3, image 1 de 2 HP Pavillion G7-2235DX Keyboard Replacement: étape 3, image 2 de 2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: étape 4, image 1 de 1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: étape 5, image 1 de 1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: étape 6, image 1 de 1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: étape 7, image 1 de 2 HP Pavillion G7-2235DX Keyboard Replacement: étape 7, image 2 de 2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
5 autres ont terminé cette réparation.
Bre'Anna Sanders
Membre depuis le 10/11/16
113 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-7, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 74
Total : 2,460
