Aller au contenu principal
HP Photosmart D110a Power Button Replacement
Ce dont vous avez besoin
  1. HP Photosmart D110a Power Button Replacement, Power Button: étape 1, image 1 de 1
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: étape 2, image 1 de 1
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: étape 3, image 1 de 3 HP Photosmart D110a Power Button Replacement: étape 3, image 2 de 3 HP Photosmart D110a Power Button Replacement: étape 3, image 3 de 3
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: étape 4, image 1 de 1
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: étape 5, image 1 de 1
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: étape 6, image 1 de 3 HP Photosmart D110a Power Button Replacement: étape 6, image 2 de 3 HP Photosmart D110a Power Button Replacement: étape 6, image 3 de 3
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: étape 7, image 1 de 3 HP Photosmart D110a Power Button Replacement: étape 7, image 2 de 3 HP Photosmart D110a Power Button Replacement: étape 7, image 3 de 3
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
Tim Wise
Membre depuis le 04/01/11
173 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 3,559
