Introduction
If the scanner glass cracks or breaks, it will need to be replaced in it's entirety. The glass is visible when you open the top of the printer so you will be able to tell if it needs replacement without taking the printer apart.
Pièces
Aucune pièce nécessaire.
Open the top of the printer. The printer should appear as shown.
  • Open the top of the printer. The printer should appear as shown.
Ajouter un commentaire
Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
  • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
  • Loosen the pieces around the edges before pulling to remove from the printer.
  • Pull the (4) trim pieces off and set them aside.
  • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
  • The side trim pieces need to be removed before the front trim pieces.
  • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
  • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
  • Both clips will come unattached and you can set the scanner flap aside.
  • Lift the scanner glass piece from the printer.
  • The scanner glass is attached to the plastic piece with adhesive tape.
  • Pull off the glass and re-set new piece of glass.
Laura
Membre depuis le 23/10/2014
628 Réputation
3 tutoriels rédigés
Équipe
Michigan Tech, Team 1-2, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 444
