Aller au contenu principal
HP Photosmart c3180 Scanner Bulb Replacement
Ce dont vous avez besoin
  1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: étape 1, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: étape 1, image 2 de 2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Scanner Bulb Replacement: étape 2, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 2, image 2 de 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Scanner Bulb Replacement: étape 3, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 3, image 2 de 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Scanner Bulb Replacement: étape 4, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 4, image 2 de 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Scanner Bulb Replacement: étape 5, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 5, image 2 de 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Scanner Bulb Replacement: étape 6, image 1 de 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Scanner Bulb Replacement: étape 7, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 7, image 2 de 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - Réponse
  8. HP Photosmart c3180 Scanner Bulb Replacement: étape 8, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 8, image 2 de 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Scanner Bulb Replacement: étape 9, image 1 de 1
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
    Garofalo - Réponse
  10. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: étape 10, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: étape 10, image 2 de 2
    • Set aside the top panel of the printer.
    • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
  11. HP Photosmart c3180 Scanner Bulb Replacement: étape 11, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 11, image 2 de 2
    • Flip the scanner carriage over to expose the connectors on the bottom.
    • Carefully remove the small cable from the connector.
    • Carefully remove the large cable from the connector.
  12. HP Photosmart c3180 Scanner Bulb Replacement: étape 12, image 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: étape 12, image 2 de 2
    • Remove the scanner carriage from the scanner tray and flip it upside down.
    • Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner bulb.
2 autres ont terminé cette réparation.
Jim
Membre depuis le 10/06/11
1 590 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 20-30, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 membres
25 tutoriels rédigés
Un commentaire
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 6,048
