Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
  1. Unplug the device from any energy sources. Lift the top cover of the scanner.
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. Carefully pull the frame away from the glass.
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. Put your finger behind the panel with the power button. Then, pull the piece outwards.
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. Unscrew the screw inside the power button panel space. Then, unscrew the screw that is across the printer slider.
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  7. Pull the white circuit board outwards which is located under the small screen.
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  8. Pull the memory card reader's circuit board out. Detach the white wiring connector from the back of the circuit board.
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  9. Put your finger behind the small screen. Then, pull it up.
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  10. Pull the printer hood upward.
    • Pull the printer hood upward.
  11. With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
    • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
  12. With the glass facing upwards, remove the screw holding the glass in place. With the glass facing upwards, remove the screw holding the glass in place.
    • With the glass facing upwards, remove the screw holding the glass in place.
  13. Lift the glass up and away from the printer.
    • Lift the glass up and away from the printer.
    • Handle glass with care.
    • Replace the broken glass piece with the replacement glass
2 autre(s) ont terminé cette réparation.
garrett hall
Membre depuis le 26/09/2012
49 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-11, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,581
