Aller au contenu principal
HP Prime Graphing Calculator G8X92A Button Panel Replacement
Ce dont vous avez besoin
  1. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: étape 1, image 1 de 2 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: étape 1, image 2 de 2
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 2, image 1 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 2, image 2 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 2, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 3, image 1 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 3, image 2 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 3, image 3 de 3
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: étape 4, image 1 de 2 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: étape 4, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 5, image 1 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 5, image 2 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 5, image 3 de 3
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 6, image 1 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 6, image 2 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 6, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 7, image 1 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 7, image 2 de 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: étape 7, image 3 de 3
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 32
Total : 752
