Aller au contenu principal
HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement
Ce dont vous avez besoin
  1. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Battery: étape 1, image 1 de 2 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Battery: étape 1, image 2 de 2
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 2, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 2, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 2, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 3, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 3, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 3, image 3 de 3
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: étape 4, image 1 de 2 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: étape 4, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 5, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 5, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 5, image 3 de 3
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 6, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 6, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 6, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 7, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 7, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 7, image 3 de 3
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
  8. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: étape 8, image 1 de 2 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: étape 8, image 2 de 2
    • Remove the lower component from the motherboard
  9. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 9, image 1 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 9, image 2 de 3 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 9, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the four screws securing the motherboard/display to the front panel.
    • Using a plastic opening tool, pry up the locking tab of the ZIF connector on the right side of the device and pull out the ribbon cable.
    • Using a plastic opening tool, gently pry apart the motherboard and the front panel.
  10. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 10, image 1 de 2 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: étape 10, image 2 de 2
    • Remove the motherboard from the display.
Un commentaire
Hi Eric,
Do you know where we could buy / get a screen replacement? I looked everywhere, but I cannot find it.
Led Hilderink - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 77
Total : 1,562
