Aller au contenu principal
HP ProBook 4320t Processor Heat Sink Replacement Guide
Ce dont vous avez besoin
  1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: étape 1, image 1 de 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: étape 1, image 2 de 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: étape 2, image 1 de 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: étape 2, image 2 de 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: étape 3, image 1 de 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: étape 4, image 1 de 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: étape 5, image 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: étape 6, image 1 de 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: étape 6, image 2 de 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: étape 7, image 1 de 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: étape 8, image 1 de 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: étape 9, image 1 de 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: étape 10, image 1 de 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: étape 11, image 1 de 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: étape 12, image 1 de 1
    • Locate silver holding panel on the left side of the computer.
  13. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 13, image 1 de 1
    • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
    • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
  14. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 14, image 1 de 1
    • Remove holding panel and put aside.
  15. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 15, image 1 de 1
    • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
  16. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 16, image 1 de 1
    • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
  17. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 17, image 1 de 1
    • Lift fan up carefully and replace.
  18. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: étape 18, image 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
  19. HP ProBook 4320t Processor Heat Sink Replacement Guide: étape 19, image 1 de 1
    • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
Eric Markham
Membre depuis le 08/29/14
227 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 1,065
