Introduction
Broken speakers can be very annoying. Replacing the old speakers can bring new life to your beats.
Ce dont vous avez besoin
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
