Aller au contenu principal
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
Ce dont vous avez besoin
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: étape 1, image 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 2, image 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 2, image 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: étape 3, image 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: étape 3, image 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: étape 3, image 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 4, image 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): étape 5, image 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): étape 5, image 2 de 2
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 6, image 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 6, image 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 6, image 3 de 3
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 7, image 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 7, image 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 7, image 3 de 3
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 8, image 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: étape 8, image 2 de 2
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
Ethan A Courtney
Membre depuis le 10/24/18
851 Réputation
7 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 24
Total : 4,080
