Aller au contenu principal
HP ProBook 440 G1 Keyboard Replacement
Ce dont vous avez besoin
  1. HP ProBook 440 G1 Keyboard Replacement, Battery: étape 1, image 1 de 2 HP ProBook 440 G1 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Keyboard Replacement: étape 2, image 1 de 2 HP ProBook 440 G1 Keyboard Replacement: étape 2, image 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Keyboard Replacement, Backplate: étape 3, image 1 de 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: étape 3, image 2 de 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: étape 3, image 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Keyboard Replacement: étape 4, image 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Keyboard Replacement, Keyboard: étape 5, image 1 de 2 HP ProBook 440 G1 Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Locate the two screws on the back of the laptop, holding the keyboard.
    • Remove the two screws using a Phillips #00 screwdriver.
  6. HP ProBook 440 G1 Keyboard Replacement: étape 6, image 1 de 1
    • Flip the computer over so as to see the keyboard.
  7. HP ProBook 440 G1 Keyboard Replacement: étape 7, image 1 de 2 HP ProBook 440 G1 Keyboard Replacement: étape 7, image 2 de 2
    • Place both hands on the keyboard and slide it back.
    • The keyboard will only slide back a small amount.
  8. HP ProBook 440 G1 Keyboard Replacement: étape 8, image 1 de 2 HP ProBook 440 G1 Keyboard Replacement: étape 8, image 2 de 2
    • Using a plastic opening tool, pull the keyboard up.
  9. HP ProBook 440 G1 Keyboard Replacement: étape 9, image 1 de 3 HP ProBook 440 G1 Keyboard Replacement: étape 9, image 2 de 3 HP ProBook 440 G1 Keyboard Replacement: étape 9, image 3 de 3
    • Locate the connector strip between the keyboard and the laptop.
    • Pull the strip away from the connector until it unplugs.
    • It may take some force to make the strip disconnect.
Ethan A Courtney
Membre depuis le 10/24/18
851 Réputation
7 tutoriels rédigés
Équipe
Un commentaire
thanks for that
sir i want original keyboard 440 G1
if u dont mine suggest me
karun kumar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 2,196
