Aller au contenu principal
HP ProBook 440 G1 Wifi Card Replacement
Ce dont vous avez besoin
  1. HP ProBook 440 G1 Wifi Card Replacement, Battery: étape 1, image 1 de 2 HP ProBook 440 G1 Wifi Card Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Wifi Card Replacement: étape 2, image 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: étape 2, image 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Wifi Card Replacement, Backplate: étape 3, image 1 de 3 HP ProBook 440 G1 Wifi Card Replacement, Backplate: étape 3, image 2 de 3 HP ProBook 440 G1 Wifi Card Replacement, Backplate: étape 3, image 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Wifi Card Replacement: étape 4, image 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: étape 5, image 1 de 2 HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: étape 5, image 2 de 2
    • Locate the Wifi card, found opposite the battery and across from the hard drive.
  6. HP ProBook 440 G1 Wifi Card Replacement: étape 6, image 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: étape 6, image 2 de 2
    • Remove the wire located near the screws on the wifi card.
  7. HP ProBook 440 G1 Wifi Card Replacement: étape 7, image 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: étape 7, image 2 de 2
    • Remove the two Phillips #00 screws holding the wifi card in place.
  8. HP ProBook 440 G1 Wifi Card Replacement: étape 8, image 1 de 1
    • Remove the wifi card.
Ethan A Courtney
Membre depuis le 10/24/18
851 Réputation
7 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 1,527
