Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ProBook 450 G2
Ce dont vous avez besoin
    1. HP ProBook 450 G2, Detaching the Bottom Cover and Battery: étape 1, image 1 de 2 HP ProBook 450 G2, Detaching the Bottom Cover and Battery: étape 1, image 2 de 2
      • Carefully remove the main battery.
      • Locate the screw on the bottom side.
      • Unscrew and remove it.
      • Carefully take off the two plastic covers.
      Demander à FixBot
      Ajouter un commentaire
    2. HP ProBook 450 G2, Disassembling the Keyboard: étape 2, image 1 de 3 HP ProBook 450 G2, Disassembling the Keyboard: étape 2, image 2 de 3 HP ProBook 450 G2, Disassembling the Keyboard: étape 2, image 3 de 3
      • Locate the three screws marked with a keyboard icon next to them.
      • Carefully unscrew and remove each of them.
      • Take a thin, flat tool, such as a guitar pick.
      • Gently insert it at the top edge of the keyboard.
      • Carefully slide it along the edge until the keyboard starts to lift or "pop" out.
      • Do not immediately pull out the keyboard.
      • Carefully locate and detach the keyboard cable connecting it to the motherboard.
      Demander à FixBot
    3. HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: étape 3, image 1 de 2 HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: étape 3, image 2 de 2
      • Locate the screw marked with a CD icon next to it.
      • Carefully unscrew and remove it.
      • Carefully pull out the CD-DVD unit.
      Demander à FixBot
    4. HP ProBook 450 G2, Extracting the Hard Drive: étape 4, image 1 de 2 HP ProBook 450 G2, Extracting the Hard Drive: étape 4, image 2 de 2
      • Locate the four screws marked.
      • Slide the disk to the right and then carefully pull it out.
      Demander à FixBot
    5. HP ProBook 450 G2, Disassembling the Casing (1/2): étape 5, image 1 de 3 HP ProBook 450 G2, Disassembling the Casing (1/2): étape 5, image 2 de 3 HP ProBook 450 G2, Disassembling the Casing (1/2): étape 5, image 3 de 3
      • On the bottom locate the 11 (M2.5x3) screws marked and 2 (M2.5x6) - picture 1.
      • On the bottom locate the 6 (M2.5x6) screws hidden under the rubbers - picture 2.
      • Under the keyboard locate the 3 (M2.5x6) screws.
      • Detach all cables connected to the motherboard.
      Demander à FixBot
    6. HP ProBook 450 G2, Disassembling the Casing (2/2): étape 6, image 1 de 2 HP ProBook 450 G2, Disassembling the Casing (2/2): étape 6, image 2 de 2
      • Carefully separate the covers.
      • Be aware that there is an additional cable underneath. Detach this cable with caution.
      Demander à FixBot
    7. HP ProBook 450 G2, Extracting the Motherboard: étape 7, image 1 de 1
      • Locate the five screws marked.
      • To more easily access and detach the cables, gently pull out the motherboard a bit.
      Demander à FixBot
    8. HP ProBook 450 G2, Dismantle cpu cooling pipe: étape 8, image 1 de 2 HP ProBook 450 G2, Dismantle cpu cooling pipe: étape 8, image 2 de 2
      • Locate the six screws marked.
      • Now you can take off cooling pipe and clean it.
      Demander à FixBot
5 autres ont terminé cette réparation.
Klemen Hodžić
Membre depuis le 11/01/20
764 Réputation
4 tutoriels rédigés
2 commentaires de tutoriel
thanks for computer education
kagizo - Réponse Partager
شكرا ليكم على الشرح
Abdo elmasry - Réponse Partager
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 53
30 derniers jours : 201
Total : 4,673
