Aller au contenu principal
HP ProBook 450 G4 Daughterboard Replacement
Ce dont vous avez besoin
  1. HP ProBook 450 G4 Daughterboard Replacement, Hard Drive: étape 1, image 1 de 2 HP ProBook 450 G4 Daughterboard Replacement, Hard Drive: étape 1, image 2 de 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Daughterboard Replacement: étape 2, image 1 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 2, image 2 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 2, image 3 de 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Daughterboard Replacement: étape 3, image 1 de 2 HP ProBook 450 G4 Daughterboard Replacement: étape 3, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Daughterboard Replacement: étape 4, image 1 de 2 HP ProBook 450 G4 Daughterboard Replacement: étape 4, image 2 de 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Daughterboard Replacement, Keyboard: étape 5, image 1 de 3 HP ProBook 450 G4 Daughterboard Replacement, Keyboard: étape 5, image 2 de 3 HP ProBook 450 G4 Daughterboard Replacement, Keyboard: étape 5, image 3 de 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Daughterboard Replacement: étape 6, image 1 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 6, image 2 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 6, image 3 de 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Daughterboard Replacement: étape 7, image 1 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 7, image 2 de 3 HP ProBook 450 G4 Daughterboard Replacement: étape 7, image 3 de 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Daughterboard Replacement: étape 8, image 1 de 2 HP ProBook 450 G4 Daughterboard Replacement: étape 8, image 2 de 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Daughterboard Replacement, Daughterboard: étape 9, image 1 de 2 HP ProBook 450 G4 Daughterboard Replacement, Daughterboard: étape 9, image 2 de 2
    • Insert the Jimmy in between the top case of the laptop and its outer frame.
    • Use a spudger to disconnect the three cable connectors.
  10. HP ProBook 450 G4 Daughterboard Replacement: étape 10, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the 3.2 mm screw.
  11. HP ProBook 450 G4 Daughterboard Replacement: étape 11, image 1 de 1
    • Remove the two 3 mm screws from the daughterboard using a Phillips #0 screwdriver.
  12. HP ProBook 450 G4 Daughterboard Replacement: étape 12, image 1 de 1
    • Lift up the daughterboard to remove from the laptop.
AidanW
Membre depuis le 02/08/24
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 20
