Introduction
If the keys on your keyboard are unresponsive or damaged, remove the keyboard for cleaning or replacement.
Ce dont vous avez besoin
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Slide the keyboard panel away from you to free it from the 4520s.
Does keyboard slide away or to right/left? thought it was to the right.
Keyboard goes directly away
To reassemble your device, follow these steps in reverse order.
7 autres ont terminé cette réparation.
