Introduction
This guide will teach you how to properly remove and replace the HDD in the ProBook 4530s.
Pièces
Aucune pièce nécessaire.
Start by flipping over the laptop onto its back.
  • Start by flipping over the laptop onto its back.
Ajouter un commentaire
Press inward on the two switches.
  • Press inward on the two switches.
  • The battery should pop out slightly.
  • Remove the battery.
  • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
  • Release the switches.
  • Slide the panel the rest of the way out.
  • Unscrew the four screws located on the edges of the base.
  • Lift enough on the right side of the HDD to make it over the plastic paneling.
  • Pull outward.
  • Remove the adhesive from the protective covering over the HDD.
  • Remove the four screws around the edges of the metal base.
  • Pull out the HDD from the base.
  • Insert the new HDD or SSD.
2 autre(s) ont terminé cette réparation.
Drew Canada
Membre depuis le 03/04/2018
836 Réputation
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 112
Total : 234
