Aller au contenu principal
HP ProBook 4530s RAM Replacement
Ce dont vous avez besoin
  1. HP ProBook 4530s RAM Replacement, Introduction: étape 1, image 1 de 1
    • Start by flipping the laptop over onto its back.
  2. HP ProBook 4530s RAM Replacement, Battery Removal: étape 2, image 1 de 1
    • Press in on both sides, the switches will release the battery.
    • The battery will pop out slightly, allowing you to pull it out.
  3. HP ProBook 4530s RAM Replacement, Bottom Panel Removal: étape 3, image 1 de 1
    • Press in on both switches, while pushing onto the plastic panel behind them.
    • The panel should slide out.
  4. HP ProBook 4530s RAM Replacement, Locate and Disassemble: étape 4, image 1 de 3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: étape 4, image 2 de 3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: étape 4, image 3 de 3
    • Locate the RAM slightly to the center-left.
    • Press outward on the metal retention arms for the RAM.
    • The RAM should pop upward slightly.
  5. HP ProBook 4530s RAM Replacement, RAM Removal: étape 5, image 1 de 1
    • Grab the RAM gently and remove at a 45 Degree angle.
6 autres ont terminé cette réparation.
Drew Canada
Membre depuis le 04/03/18
1 370 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 55
Total : 3,056
