Introduction
This will teach you the easiest way I found to remove and replace the WiFi NIC in the ProBook 4530s.
Start by flipping over the laptop onto its back.
  • Start by flipping over the laptop onto its back.
Ajouter un commentaire
Push both switches inward. The battery should pop out a slight amount.
  • Push both switches inward. The battery should pop out a slight amount.
  • Pull out the battery.
  • Press on both of the battery switches then push on the back panel forward.
  • It should pop out slightly.
  • Lift and slide the panel off.
  • Locate the WiFi card outlined in red.
  • The golden connectors will need to be popped off. They are marked in blue.
  • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
  • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  • Remove the two screws that secure the card down.
  • The card should pop up at a 45 degree angle.
  • Pull the card straight out.
2 autre(s) ont terminé cette réparation.
Drew Canada
Membre depuis le 03/04/2018
836 Réputation
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 22
Total : 86
