Aller au contenu principal
HP ProBook 4530s WiFi Card Replacement
Ce dont vous avez besoin
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: étape 1, image 1 de 2 HP ProBook 4530s WiFi Card Replacement, Introduction: étape 1, image 2 de 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: étape 2, image 1 de 1
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: étape 3, image 1 de 1
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: étape 4, image 1 de 2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: étape 4, image 2 de 2
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: étape 5, image 1 de 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: étape 5, image 2 de 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: étape 5, image 3 de 3
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
5 autres ont terminé cette réparation.
Drew Canada
Membre depuis le 04/03/18
1 382 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 25
Total : 3,687
