Aller au contenu principal
HP ProBook 4540s Back Door Replacement
Ce dont vous avez besoin
  1. HP ProBook 4540s Back Door Replacement, Battery: étape 1, image 1 de 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Back Door Replacement, Bottom Door: étape 2, image 1 de 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
3 autres ont terminé cette réparation.
Amber Schindler
Membre depuis le 10/26/16
1 027 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team 1-5, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 24
Total : 2,090
