Aller au contenu principal
HP ProBook 645 Keyboard Replacement
Ce dont vous avez besoin
  1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: étape 1, image 1 de 1
    • Remove the two screws at the two indicated locations with the phillips head screw driver.
  2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: étape 2, image 1 de 1
    • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
  3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: étape 3, image 1 de 1
    • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
    • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
3 autres ont terminé cette réparation.
Doug
Membre depuis le 04/02/15
191 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 4,501
