Introduction
This guide will give you step-by-step instructions on how to safely remove the battery from your HP ProBook x360 11 G5 EE laptop. The battery is an essential piece of your laptop that powers your entire device. If the laptop powers on only when the adapter is plugged in regardless of the time spent charging, then the battery is faulty.
Ce dont vous avez besoin
Remove the 4.1 mm screws with a T5 Torx screwdriver.
Remove the 4.1 mm screws using a JIS #0 screwdriver.
