Introduction
One of the most frustrating things that can happen to your tablet is the inability for it to charge; the tablet is practically useless if you're unable to charge it. This guide will breakdown all the necessary steps to ensure that you're able to charge life into your tablet. In this guide, you will be removing the following:
- Back Cover
- Battery
- Charging Port
Prepare your required tools, a new charging port for your tablet, and set aside about 10 to 20 minutes to delve into the inner workings of your HP Slate.
Pièces
Aucune pièce spécifiée.
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
34 autre(s) ont terminé cette réparation.
14 commentaires
where do you get the replacement parts for charging port
Since HP does not supply the replacement ribbon, or many other parts for that matter, it is easiest to search on eBay and/or Craigslist for the parts needed. I found that the UK version of Amazon and eBay offer the best availability for such parts.
Zachary -
