Aller au contenu principal
HP Spectre 13-4002dx Display Replacement
Ce dont vous avez besoin
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: étape 1, image 1 de 3 HP Spectre 13-4002dx Display Replacement, Motherboard: étape 1, image 2 de 3 HP Spectre 13-4002dx Display Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: étape 2, image 1 de 1
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: étape 3, image 1 de 2 HP Spectre 13-4002dx Display Replacement: étape 3, image 2 de 2
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: étape 4, image 1 de 2 HP Spectre 13-4002dx Display Replacement: étape 4, image 2 de 2
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
Aidan
Membre depuis le 02/20/20
105 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 460
