Aller au contenu principal
HP Spectre 13-4002dx Speakers Replacement
Ce dont vous avez besoin
  1. HP Spectre 13-4002dx Speakers Replacement, Bottom Case: étape 1, image 1 de 2 HP Spectre 13-4002dx Speakers Replacement, Bottom Case: étape 1, image 2 de 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Speakers Replacement: étape 2, image 1 de 2 HP Spectre 13-4002dx Speakers Replacement: étape 2, image 2 de 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Speakers Replacement, Battery: étape 3, image 1 de 3 HP Spectre 13-4002dx Speakers Replacement, Battery: étape 3, image 2 de 3 HP Spectre 13-4002dx Speakers Replacement, Battery: étape 3, image 3 de 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Speakers Replacement: étape 4, image 1 de 3 HP Spectre 13-4002dx Speakers Replacement: étape 4, image 2 de 3 HP Spectre 13-4002dx Speakers Replacement: étape 4, image 3 de 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Speakers Replacement: étape 5, image 1 de 2 HP Spectre 13-4002dx Speakers Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Speakers Replacement: étape 6, image 1 de 3 HP Spectre 13-4002dx Speakers Replacement: étape 6, image 2 de 3 HP Spectre 13-4002dx Speakers Replacement: étape 6, image 3 de 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Speakers Replacement: étape 7, image 1 de 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Speakers Replacement, Speakers: étape 8, image 1 de 3 HP Spectre 13-4002dx Speakers Replacement, Speakers: étape 8, image 2 de 3 HP Spectre 13-4002dx Speakers Replacement, Speakers: étape 8, image 3 de 3
    • Remove four screws located on the bottom corners of speaker covers using the Phillips #00 screwdrivers.
    • Disconnect both 3-pin cables located on the edge of the computer.
    • Remove both speakers.
Brian Horn
Membre depuis le 02/12/20
73 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 198
