Aller au contenu principal
HP Spectre x360 13-4103dx Fan Replacement
Ce dont vous avez besoin
  1. HP Spectre x360 13-4103dx Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Fan Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Fan Replacement: étape 3, image 1 de 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Fan Replacement, Fan: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the screws from the fan.
  5. HP Spectre x360 13-4103dx Fan Replacement: étape 5, image 1 de 1
    • Disconnect the group of fan wires from the motherboard.
    • Lift the fan up to remove it from the laptop.
Andrew Medeiros
Membre depuis le 10/25/21
511 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 342
