Aller au contenu principal
HP Spectre x360 13-ac023dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: étape 1, image 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 2, image 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 2, image 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 2, image 3 de 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 3, image 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 3, image 2 de 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: étape 4, image 1 de 1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 5, image 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 5, image 2 de 2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 6, image 1 de 1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: étape 7, image 1 de 1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 8, image 1 de 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 9, image 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 9, image 2 de 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: étape 10, image 1 de 1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 11, image 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 11, image 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 11, image 3 de 3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 12, image 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 12, image 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 12, image 3 de 3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: étape 13, image 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: étape 13, image 2 de 2
    • Carefully lift and remove the motherboard.
Jonathan
Membre depuis le 10/21/19
486 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
3 membres
6 tutoriels rédigés
Un commentaire
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 26
Total : 3,371
