Aller au contenu principal
HP Spectre x360 13-ac023dx WiFi Card Replacement
Ce dont vous avez besoin
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: étape 1, image 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 2, image 1 de 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 2, image 2 de 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 2, image 3 de 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 3, image 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 3, image 2 de 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: étape 4, image 1 de 1
    • Locate the WiFi card.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 5, image 1 de 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 6, image 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: étape 6, image 2 de 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
Jonathan
Membre depuis le 10/21/19
486 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 1,805
