Aller au contenu principal
HP Spectre x360 13t-4000 Fan Replacement
Ce dont vous avez besoin
  1. HP Spectre x360 13t-4000 Fan Replacement, Bottom Cover: étape 1, image 1 de 2 HP Spectre x360 13t-4000 Fan Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Fan Replacement: étape 2, image 1 de 2 HP Spectre x360 13t-4000 Fan Replacement: étape 2, image 2 de 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Fan Replacement: étape 3, image 1 de 3 HP Spectre x360 13t-4000 Fan Replacement: étape 3, image 2 de 3 HP Spectre x360 13t-4000 Fan Replacement: étape 3, image 3 de 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Fan Replacement, Fan: étape 4, image 1 de 3 HP Spectre x360 13t-4000 Fan Replacement, Fan: étape 4, image 2 de 3 HP Spectre x360 13t-4000 Fan Replacement, Fan: étape 4, image 3 de 3
    • Use a Phillips #0 screwdriver to unscrew and remove the two 4 mm screws that secure the fan.
    • Use the same screwdriver to remove the four 3 mm screws to free the heat sink.
  5. HP Spectre x360 13t-4000 Fan Replacement: étape 5, image 1 de 1
    • Remove the fan cable.
  6. HP Spectre x360 13t-4000 Fan Replacement: étape 6, image 1 de 3 HP Spectre x360 13t-4000 Fan Replacement: étape 6, image 2 de 3 HP Spectre x360 13t-4000 Fan Replacement: étape 6, image 3 de 3
    • Peal off the tape with the metal shield, heat sink, and the fan attached to it.
    • Gently separate the fan from the heat sink in order to replace the fan.
Justin Dages
Membre depuis le 03/28/23
361 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 2-5, Harley Spring 2023 Membre de l'équipe IUPUI, Team 2-5, Harley Spring 2023
IUPUI-HARLEY-S23S2G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 96
