Introduction
This guide will instruct you on how to remove and replace the speakers. Replacement of the speakers may be necessary if the speakers are not outputting any sound or outputting a distorted sound.
Ce dont vous avez besoin
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
With the backplate and battery removed from the device, remove the three 2mm screws using the Phillips #0 screwdriver.
