Introduction
This guide will instruct you on how to remove and replace the Wifi Adapter. Replacement of the wifi adapter may be necessary if the device cannot connect to the internet.
Ce dont vous avez besoin
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
Using a Phillips#0 screwdriver, remove the 2 mm screw.
Located to the right of the screw, there are two wires connected to the adapter. Using tweezers, carefully remove the wires.
Now you can remove the adapter by pulling it from its socket.
