Aller au contenu principal
HP Split x2 13-g210dx Audio Ports Replacement
Ce dont vous avez besoin
  1. HP Split x2 13-g210dx Audio Ports Replacement, Back Panel: étape 1, image 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Audio Ports Replacement, Battery: étape 2, image 1 de 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Audio Ports Replacement: étape 3, image 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Audio Ports Replacement: étape 4, image 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: étape 4, image 2 de 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Audio Ports Replacement, Audio Port: étape 5, image 1 de 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Audio Ports Replacement: étape 6, image 1 de 3 HP Split x2 13-g210dx Audio Ports Replacement: étape 6, image 2 de 3 HP Split x2 13-g210dx Audio Ports Replacement: étape 6, image 3 de 3
    J'achète
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  7. HP Split x2 13-g210dx Audio Ports Replacement: étape 7, image 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: étape 7, image 2 de 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  8. HP Split x2 13-g210dx Audio Ports Replacement: étape 8, image 1 de 1
    • Lift the Audio port away from the device.
Isaac Van Baren
Membre depuis le 02/26/19
315 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 223
