Aller au contenu principal
HP Split x2 13-g210dx Back Panel Replacement
Ce dont vous avez besoin
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Isaac Van Baren
Membre depuis le 02/26/19
315 Réputation
2 tutoriels rédigés
Un commentaire
How do I put the felt cover back on?
Prince Phoenix - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 376
