Introduction
Did you accidentally drop your device and shatter the screen? This guide will instruct you how to replace your broken screen. The first five steps tell you how to remove the rear cover of the case. The remaining six steps explain how to replace the screen.
Ce dont vous avez besoin
Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
The last attachment to the screen is the bronze colored display cable connector.
Use a pair of tweezers to lift the metal bar and swing it to the other side on top of the cable.
Pull in the direction of the cable to remove the connector.
11 autres ont terminé cette réparation.
5 commentaires
This is not helpful because the one I am working on has no screws.
I also have a Split x2 with no screws
I want change my screen because My screen is broken but I do not know , where I can buy my screen
ebay or amazon
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
