Aller au contenu principal
HP Stream 11-d008TU Heatsink Replacement
Ce dont vous avez besoin
  1. HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: étape 1, image 1 de 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: étape 1, image 2 de 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: étape 1, image 3 de 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Heatsink Replacement, Screw removal: étape 2, image 1 de 2 HP Stream 11-d008TU Heatsink Replacement, Screw removal: étape 2, image 2 de 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: étape 3, image 1 de 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: étape 3, image 2 de 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: étape 3, image 3 de 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: étape 4, image 1 de 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: étape 4, image 2 de 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: étape 4, image 3 de 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Heatsink Replacement, Unscrew the heatsink: étape 5, image 1 de 1
    • Unscrew the four 2.5mm M2x2.5 PH-0 Phillips head screws in reverse numerical order (4-3-2-1)
    • 4: Bottom left | 3: Top Right | 2: Bottom Right | 1: Top Left
  6. HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: étape 6, image 1 de 2 HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: étape 6, image 2 de 2
    • Lift the heatsink
CONVERSION
Membre depuis le 03/07/20
1 279 Réputation
8 tutoriels rédigés
Équipe
Australia Membre de l'équipe Australia
Community
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 83
