Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Stream 11-d010nr Clickpad Replacement
Ce dont vous avez besoin
  1. HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: étape 1, image 1 de 2 HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: étape 1, image 2 de 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    Demander à FixBot
  2. HP Stream 11-d010nr Clickpad Replacement, Unscrew the back cover: étape 2, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    Demander à FixBot
  3. HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: étape 3, image 1 de 2 HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: étape 3, image 2 de 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    Demander à FixBot
  4. HP Stream 11-d010nr Clickpad Replacement, Identify the connectors: étape 4, image 1 de 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    Demander à FixBot
  5. HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: étape 5, image 1 de 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: étape 5, image 2 de 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: étape 5, image 3 de 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    Demander à FixBot
  6. HP Stream 11-d010nr Clickpad Replacement, Lift the keyboard out: étape 6, image 1 de 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    Demander à FixBot
  7. HP Stream 11-d010nr Clickpad Replacement, Clickpad: étape 7, image 1 de 2 HP Stream 11-d010nr Clickpad Replacement, Clickpad: étape 7, image 2 de 2
    • Remove the two 2mm #000 Phillips screws.
    Demander à FixBot
  8. HP Stream 11-d010nr Clickpad Replacement: étape 8, image 1 de 1
    • Release the clickpad by lifting the keyboard up.
    • When installing the new clickpad, make sure the black tabs go into the laptop.
    Demander à FixBot
Josh Corrigan
Membre depuis le 01/24/19
353 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 membres
11 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 46
Total : 531
