Aller au contenu principal
HP Stream 11-d010nr Speaker Replacement
Ce dont vous avez besoin
  1. HP Stream 11-d010nr Speaker Replacement, Keyboard: étape 1, image 1 de 2 HP Stream 11-d010nr Speaker Replacement, Keyboard: étape 1, image 2 de 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Speaker Replacement: étape 2, image 1 de 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Speaker Replacement: étape 3, image 1 de 2 HP Stream 11-d010nr Speaker Replacement: étape 3, image 2 de 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Speaker Replacement: étape 4, image 1 de 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Speaker Replacement: étape 5, image 1 de 3 HP Stream 11-d010nr Speaker Replacement: étape 5, image 2 de 3 HP Stream 11-d010nr Speaker Replacement: étape 5, image 3 de 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Speaker Replacement: étape 6, image 1 de 1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Speaker Replacement, Speaker: étape 7, image 1 de 1
    • Undo 4 3mm screws attached to the speaker.
  8. HP Stream 11-d010nr Speaker Replacement: étape 8, image 1 de 1
    • Remove connecting wire from the Motherboard.
  9. HP Stream 11-d010nr Speaker Replacement: étape 9, image 1 de 1
    • Extract speakers after disconnecting.
Tristan Thompson
Membre depuis le 10/03/22
97 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 104
