Aller au contenu principal
HP Stream 11-d020nr Lid Replacement
Ce dont vous avez besoin
  1. HP Stream 11-d020nr Lid Replacement, Lower Case: étape 1, image 1 de 3 HP Stream 11-d020nr Lid Replacement, Lower Case: étape 1, image 2 de 3 HP Stream 11-d020nr Lid Replacement, Lower Case: étape 1, image 3 de 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lid Replacement: étape 2, image 1 de 2 HP Stream 11-d020nr Lid Replacement: étape 2, image 2 de 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lid Replacement: étape 3, image 1 de 3 HP Stream 11-d020nr Lid Replacement: étape 3, image 2 de 3 HP Stream 11-d020nr Lid Replacement: étape 3, image 3 de 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lid Replacement: étape 4, image 1 de 3 HP Stream 11-d020nr Lid Replacement: étape 4, image 2 de 3 HP Stream 11-d020nr Lid Replacement: étape 4, image 3 de 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Lid Replacement, Keyboard: étape 5, image 1 de 2 HP Stream 11-d020nr Lid Replacement, Keyboard: étape 5, image 2 de 2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Lid Replacement: étape 6, image 1 de 3 HP Stream 11-d020nr Lid Replacement: étape 6, image 2 de 3 HP Stream 11-d020nr Lid Replacement: étape 6, image 3 de 3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
  7. HP Stream 11-d020nr Lid Replacement, Lid: étape 7, image 1 de 3 HP Stream 11-d020nr Lid Replacement, Lid: étape 7, image 2 de 3 HP Stream 11-d020nr Lid Replacement, Lid: étape 7, image 3 de 3
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
  8. HP Stream 11-d020nr Lid Replacement: étape 8, image 1 de 3 HP Stream 11-d020nr Lid Replacement: étape 8, image 2 de 3 HP Stream 11-d020nr Lid Replacement: étape 8, image 3 de 3
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
Spenser Mason
Membre depuis le 02/04/16
1 763 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 3-5, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 485
