Aller au contenu principal
HP Stream 11-r020nr Keyboard Panel Replacement
Ce dont vous avez besoin
  1. HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: étape 1, image 1 de 2 HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: étape 1, image 2 de 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Keyboard Panel Replacement: étape 2, image 1 de 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Keyboard Panel Replacement: étape 3, image 1 de 2 HP Stream 11-r020nr Keyboard Panel Replacement: étape 3, image 2 de 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Keyboard Panel Replacement: étape 4, image 1 de 2 HP Stream 11-r020nr Keyboard Panel Replacement: étape 4, image 2 de 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Keyboard Panel Replacement: étape 5, image 1 de 2 HP Stream 11-r020nr Keyboard Panel Replacement: étape 5, image 2 de 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Keyboard Panel Replacement: étape 6, image 1 de 2 HP Stream 11-r020nr Keyboard Panel Replacement: étape 6, image 2 de 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Keyboard Panel Replacement: étape 7, image 1 de 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
Un commentaire
Hello, I have an hp stream 11 inch laptop and would like to know how do you remove the keys from the keyboard to replace the palmrest or key board cover?
keisha manley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,757
