Introduction
Do you think there is an issue with your HP Stream 11-y010nr webcam? Is the webcam image coming out fuzzy or simply not working? The first thing that you should do is look over our troubleshooting page and see if you can diagnose the potential problem. HP Stream 11-y010nr Troubleshooting
This guide will take you through the necessary steps to properly remove and replace the webcam. Prior to beginning, ensure the laptop is completely powered off such that it will not interfere with the steps in this guide.
Ce dont vous avez besoin
Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
Use your fingers or a spudger to pull the battery cable out from its connector.
