Aller au contenu principal
HP Stream 11-y012nr Battery Replacement
Ce dont vous avez besoin
  1. HP Stream 11-y012nr Battery  Replacement, Battery: étape 1, image 1 de 3 HP Stream 11-y012nr Battery  Replacement, Battery: étape 1, image 2 de 3 HP Stream 11-y012nr Battery  Replacement, Battery: étape 1, image 3 de 3
    • Before disassembly, power off the device and unplug it from the charger.
    • Turn the laptop over to access the lower case.
    • Using a metal spudger, remove the two horizontal screw covers.
  2. HP Stream 11-y012nr Battery  Replacement: étape 2, image 1 de 2 HP Stream 11-y012nr Battery  Replacement: étape 2, image 2 de 2
    • Remove the seven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-y012nr Battery  Replacement: étape 3, image 1 de 3 HP Stream 11-y012nr Battery  Replacement: étape 3, image 2 de 3 HP Stream 11-y012nr Battery  Replacement: étape 3, image 3 de 3
    • When using the metal spudger, be careful to not press into the components and circuits under the keyboard.
    • Turn the laptop upright and lift the screen.
    • Use the metal spudger to carefully pry the plastic keyboard from the base of the laptop.
    • Work the spudger carefully and slowly around the cover to release the clips holding it together. Be patient since there are a lot of clips attaching the laptop base to the keyboard.
    • Gently lift up the keyboard.
  4. HP Stream 11-y012nr Battery  Replacement: étape 4, image 1 de 3 HP Stream 11-y012nr Battery  Replacement: étape 4, image 2 de 3 HP Stream 11-y012nr Battery  Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • The keyboard is attached by three cables. Be careful not to lift the cover too far so you do not damage these cables.
    • Using tweezers, unplug the three cables attached to the keyboard. To do so you will find where the wires end (the three red marks). Use tweezers or your fingers to pinch the plastic piece holding the wires, and gently pull the piece out. After that it should disconnect.
    • Lift up the plastic keyboard cover.
  5. HP Stream 11-y012nr Battery  Replacement: étape 5, image 1 de 2 HP Stream 11-y012nr Battery  Replacement: étape 5, image 2 de 2
    • Using tweezers or a plastic spudger, disconnect the two bundled cable connectors connecting the battery to the motherboard.
  6. HP Stream 11-y012nr Battery  Replacement: étape 6, image 1 de 3 HP Stream 11-y012nr Battery  Replacement: étape 6, image 2 de 3 HP Stream 11-y012nr Battery  Replacement: étape 6, image 3 de 3
    • Unscrew the seven 3.3mm Phillips #000 screws.
    • Gently lift the battery out.
Mahar Senan
Membre depuis le 02/06/19
233 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S18-G8, Lore Winter 2019 Membre de l'équipe UC Davis, Team S18-G8, Lore Winter 2019
UCD-LORE-W19S18G8
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 1,442
