Introduction
The motherboard replacement guide will assist the user in removal and installation instructions for the HP Stream 13-c110nr.
Ce dont vous avez besoin
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Use a pick to disconnect the USB/Card Reader cable from the System Board.
Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
Place two (2) screws on magnetic mat for reassembly.
