Aller au contenu principal
HP Stream 13-c110nr USB/Card Reader Board Replacement
Ce dont vous avez besoin
  1. HP Stream 13-c110nr USB/Card Reader Board Replacement, Keyboard Assembly: étape 1, image 1 de 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 2, image 1 de 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 3, image 1 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 3, image 2 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 3, image 3 de 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 4, image 1 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 4, image 2 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 5, image 1 de 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 6, image 1 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 6, image 2 de 3 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 6, image 3 de 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 7, image 1 de 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 8, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 8, image 2 de 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 9, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 9, image 2 de 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 10, image 1 de 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr USB/Card Reader Board Replacement, Battery Assembly: étape 11, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement, Battery Assembly: étape 11, image 2 de 2
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 12, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 12, image 2 de 2
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 13, image 1 de 1
    • Remove Battery Assembly from device.
  14. HP Stream 13-c110nr USB/Card Reader Board Replacement, USB/Card Reader Board: étape 14, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement, USB/Card Reader Board: étape 14, image 2 de 2
    • Use a pick to disconnect the USB/Card Reader cable from the System Board.
  15. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 15, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 15, image 2 de 2
    • Remove three (3) Phillips P0 PM2.0x3.0 mm screws.
    • Place three (3) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 16, image 1 de 2 HP Stream 13-c110nr USB/Card Reader Board Replacement: étape 16, image 2 de 2
    • Remove the USB/Card Reader board assembly from the device.
Stacey Deel
Membre depuis le 01/31/19
1 147 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 221
