Aller au contenu principal
HP Stream x360 11-p010nr Battery Replacement
Ce dont vous avez besoin
  1. HP Stream x360 11-p010nr Battery Replacement, Battery: étape 1, image 1 de 3 HP Stream x360 11-p010nr Battery Replacement, Battery: étape 1, image 2 de 3 HP Stream x360 11-p010nr Battery Replacement, Battery: étape 1, image 3 de 3
    • First, make sure the laptop is completely powered off and not charging to avoid electric shock.
    • Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
    • Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
    • Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
    • The rubber feet near the speakers have no screws.
  2. HP Stream x360 11-p010nr Battery Replacement: étape 2, image 1 de 2 HP Stream x360 11-p010nr Battery Replacement: étape 2, image 2 de 2
    • After removing all the screws, slowly and carefully lift the back cover, exposing the internal components.
    • Be careful not to damage the blue strip when opening the back case.
  3. HP Stream x360 11-p010nr Battery Replacement: étape 3, image 1 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 3, image 2 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 3, image 3 de 3
    • Carefully detach the blue strip that connects the back cover to the internals.
    • Make sure the blue tab is facing upwards when reassembling.
  4. HP Stream x360 11-p010nr Battery Replacement: étape 4, image 1 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 4, image 2 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 4, image 3 de 3
    • Using the JIS J0 screwdriver, unscrew the 6.5 mm screws surrounding the battery.
  5. HP Stream x360 11-p010nr Battery Replacement: étape 5, image 1 de 1
    • Carefully remove the surrounding wire away from the battery
  6. HP Stream x360 11-p010nr Battery Replacement: étape 6, image 1 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 6, image 2 de 3 HP Stream x360 11-p010nr Battery Replacement: étape 6, image 3 de 3
    • Lastly, unhook the clip connecting the battery to the motherboard by pushing it away from the slot.
    • At this point, everything should be disconnected, simply remove the battery. Be sure to maneuver around the wire that runs between the middle of the battery.
5 autres ont terminé cette réparation.
Abdulaziz Alkulaib
Membre depuis le 03/09/17
116 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S7-G4, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S7-G4, Cagle Spring 2017
USFT-CAGLE-S17S7G4
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 3,784
