Introduction
If your keyboard has become damaged or broken, this guide will walk you through the steps of replacing the keyboard in an HP Stream x360 11-p015wm. Follow along, step-by-step to safely remove your keyboard and then follow the instruction in reverse to reassemble your laptop with its new keyboard! Be sure to back-up your files before undergoing this repair.
Ce dont vous avez besoin
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
Remove the metal bracket.
