Aller au contenu principal
HP Stream x360 11-p015wm Motherboard Replacement
Ce dont vous avez besoin
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: étape 1, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    JIS Driver Set
    $19.99
    J'achète
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: étape 3, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 3, image 2 de 2
    iFixit Opening Tool
    $1.99
    J'achète
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: étape 4, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 4, image 2 de 2
    $3.99
    J'achète
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: étape 6, image 1 de 3 HP Stream x360 11-p015wm Motherboard Replacement: étape 6, image 2 de 3 HP Stream x360 11-p015wm Motherboard Replacement: étape 6, image 3 de 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: étape 7, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 7, image 2 de 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: étape 8, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 8, image 2 de 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: étape 9, image 1 de 3 HP Stream x360 11-p015wm Motherboard Replacement: étape 9, image 2 de 3 HP Stream x360 11-p015wm Motherboard Replacement: étape 9, image 3 de 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: étape 10, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 10, image 2 de 2
  11. HP Stream x360 11-p015wm Motherboard Replacement: étape 11, image 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: étape 11, image 2 de 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
Meredith Buganski
Membre depuis le 11/11/19
145 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G3, Stella Fall 2019 Membre de l'équipe IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 668
