Introduction
This guide will walk you through the steps of replacing the motherboard in an HP Stream x360 11-p015wm. The motherboard is an important part of the computer hardware and contains multiple main components. Follow along, step-by-step to safely remove your motherboard and then follow the instruction in reverse to reassemble your laptop! Be sure to back-up your files before undergoing this repair.
Ce dont vous avez besoin
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
