Introduction
Use this guide to replace the motherboard.
Ce dont vous avez besoin
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Use the edge of a plastic opening tool to peel up the two pieces of copper tape covering the USB connector board near the battery and the motherboard.
Pull the vibrator motor connector straight away from its socket on the USB connector board.
Remove the USB connector board from the TouchPad.
NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
3 autres ont terminé cette réparation.
