Aller au contenu principal
HP TouchSmart 15-r015dx Screen Replacement
Ce dont vous avez besoin
  1. HP TouchSmart 15-r015dx Screen Replacement, Screen: étape 1, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: étape 1, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: étape 1, image 3 de 3
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. HP TouchSmart 15-r015dx Screen Replacement: étape 2, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 2, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 2, image 3 de 3
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
  3. HP TouchSmart 15-r015dx Screen Replacement: étape 3, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 3, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 3, image 3 de 3
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
  4. HP TouchSmart 15-r015dx Screen Replacement: étape 4, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 4, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 4, image 3 de 3
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
  5. HP TouchSmart 15-r015dx Screen Replacement: étape 5, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 5, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 5, image 3 de 3
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
  6. HP TouchSmart 15-r015dx Screen Replacement: étape 6, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 6, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 6, image 3 de 3
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
  7. HP TouchSmart 15-r015dx Screen Replacement: étape 7, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 7, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 7, image 3 de 3
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
    • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
  8. HP TouchSmart 15-r015dx Screen Replacement: étape 8, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 8, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 8, image 3 de 3
    • Locate the connection point.
    • Slowly and carefully peel off.
  9. HP TouchSmart 15-r015dx Screen Replacement: étape 9, image 1 de 2 HP TouchSmart 15-r015dx Screen Replacement: étape 9, image 2 de 2
    • Isolate the touchscreen from the keyboard.
  10. HP TouchSmart 15-r015dx Screen Replacement: étape 10, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 10, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 10, image 3 de 3
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
  11. HP TouchSmart 15-r015dx Screen Replacement: étape 11, image 1 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 11, image 2 de 3 HP TouchSmart 15-r015dx Screen Replacement: étape 11, image 3 de 3
    • Using the sharp end of the pry tool, separate the plastic from the screen.
  12. HP TouchSmart 15-r015dx Screen Replacement: étape 12, image 1 de 1
    • Now it is time to reassemble your device with a new screen.
3 autres ont terminé cette réparation.
Gabriel Terrasas
Membre depuis le 11/30/17
304 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Amazing work. I would not change a thing.
Dan Hartzell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,187
